Show proposed path
Dear all,
I am developing small application using revit api using C#.net i.e. moving precast element from storage area to the actual location in BIM model and display proposed path and actual path while moving element.
I have some queries regarding Revit api as below,
1. Please give me source code to add vertical and horizontal storage area using Revit api in BIM model.
2.Source code to display proposed path when select an element that are present in storage area using Revit api.
Please go through the attached document where black line shows the proposed path of element from storage area which is display in green color to the actual location and grey line shows the actual path while moving element from storage area to the location in BIM.
Please provide solution on my above queries as early as possible.
Regards
Sonal
