Set the drop down box for the parameter value field with tool tips
I am new to Revit API development
Reference to the below code snap its possible to set the drop down box for the parameter value field with tool tips !?
*Appreciate the explanation with a small  code snap,possible with below example.
FamilyManager familyMgr = doc.FamilyManager;
    FamilyParameter param = familyMgr.get_Parameter(
      "Width" );
    if( null == param )
      param = doc.FamilyManager.AddParameter(
        "Width", BuiltInParameterGroup.PG_GEOMETRY,
        ParameterType.Length, true );
    familyMgr.Set( param, 0.2 ); // set the value
Navan.
jeremytammik
Dear Navan,
Thank you for your query.
If you are new to the Revit API, I highly recommend working through the Revit API getting started material first of all, especially the DevTV and My First Revit Plugin tutorials:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Regarding the question you raise, I hope this will be of use:
http://thebuildingcoder.typepad.com/blog/2015/11/drop-down-enumerated-parameter-values.html
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
