Show modeless WinForms/WPF dialogs centerd on Revit's window
christostsar
christostsar
Is it possible to show a modeless WinForms or WPF dialog cented on Revit's window?
How would the window position and width/height be retrieved for this to be possible?
RPTHOMAS108
Yes but you have to set the parent/owner
For WPF use
Dim Win As New Window()
Dim WHlp1 As New Interop.WindowInteropHelper(Win)
WHlp1.Owner = commandData.Application.MainWindowHandle
For Forms use
    Public Class RevitWindow
        Implements IWin32Window
        Public ReadOnly Property Handle As IntPtr Implements IWin32Window.Handle
        Public Sub New(UIApp As UIApplication)
            Handle = UIApp.MainWindowHandle
        End Sub
    End Class
    Private Function Obj_XXa(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
        Dim RW As New RevitWindow(commandData.Application)
        Dim Form1 As New Windows.Forms.Form
        Form1.ShowDialog(RW)
        Return Result.Succeeded
    End Function
