Show/Hide Grid Bubbles
hoanghd218
Message 1 of 1
hoanghd218
Hi everybody
Recently, I'm creating an External Command to Hide or Show Grid Bubble.
Here is my simple Code ,when the command had completed , not things change in the active view but when I select a certain grid the check box has checked - the bubble not show.
#region Namespaces
using System;
using System.Collections.Generic;
using System.Diagnostics;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System.Linq;
#endregion
namespace HoangHien
    [Transaction(TransactionMode.Manual)]
    public class Template : IExternalCommand
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            // Access current selection
            Selection sel = uidoc.Selection;
            var g = doc.GetElement(sel.GetElementIds().First()) as Grid;
            using (Transaction tx = new Transaction(doc))
                tx.Start("Transaction Name");
                g.ShowBubbleInView(DatumEnds.End0, doc.ActiveView);
                //uidoc.RefreshActiveView();.
                tx.Commit();
            doc.Regenerate();
            return Result.Succeeded;
Thank you for your help!
Replies (0)
