show hidden lines of element obscured by other element
dieter.stragier
dieter.stragier
When a view "show hidden lines" property is set to "by discipline"
is there a method to set obscured element to show their hidden lines through the api?
and create a selection filter for object that are obscured by other elements?
Mohamed_Arshad
HI @dieter.stragier
      In Revit API you can't able to set show hidden lines by selecting Elements, like we do manually. Directly you need to change the View Parameter Value to all. So that Hidden lines will be visible.
@jeremy_tammik  Kindly give your valuable suggestion on this 🙂
Hope this will Help 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
