Shortcut for API
Shortcut for API
Shortcut for API
Hi friends,
how can i a shortcut creat for API?
jeremytammik
Dear Pascal,
In case you happen to mean "how can I define a shortcut key for an external command", I believe the answer is "the same way as for any built-in command".
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thank you Jeremy, i will try.
