Shortcut custom ribbon tab or panel
is there a way to create a shortcut for my custom ribbon tab? I want to press the "Alt" button and navigate to "MyCustom" tab as you can see in the attached screenshot.
Thanks for your help.
Greetings
jeremytammik
I am not aware of any Revit API support for this.
However, you can almost certainly achieve what you wish using the Windows API and .NET framework.
The simplest solution that you might want to try out first is to prepend an ampersand '&' to your desired shortcut character:
https://stackoverflow.com/questions/4625820/how-can-you-create-alt-shortcuts-in-a-windows-forms-appl...
Jeremy Tammik
Developer Technical Services
The Building Coder
