Revit Warnings not working at all
eduard.bucsa
eduard.bucsa
For a couple of days, after updating Revit 2020.1 from my Autodesk Desktop App, I noticed that the warning messages no longer appear (at all, of any sorts) and neither the Warnings button on the Manage tab is not opening at all. It's like no action has been taken after I clicked that button.
At first I thought it was because of possible model errors. Opened the project in Audit mode. Nothing appeared like I didn't even opened it with Audit. No report of any sorts. After this I thought the software is the issue so, I went ahead and even reinstalled Revit. The problem persists.
Is there some problem in the model? I tried with other models/projects. Same issue.
Does anyone know what could be going on? You may guess that this makes the modelling almost impossible.
PS:
Saw a similar post on this, but it didn't work for me as the software was already updated.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
jeremytammik
Dear Eduard,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
