Sheet Parameter - BuiltInParameter.SHEET_COLLECTION_NAME is null for all Sheets
Sean_Page
Message 1 of 8
Sean_Page
According to the SDK, there is a new BIP SHEET_COLLECTION_NAME parameter that I assume should give us the Collection Name, but when I attempt to use it in a PVP or get retrieve the value, it is always null.
Is there a reason why this parameter wouldn't be working or providing a value?
Also, it does not show up in RevitLookup.
Sean Page, AIA, NCARB, LEED AP
Senior Partner, Computational Designer, Architect
Replies (7)
Message 2 of 8
ricaun
The parameter in the image is a Integer.
AsString should return null because is the wrong type. The AsValueString return Yes, probably this parameter is a Yes/No.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 3 of 8
Moustafa_K
My understanding of sheet collection, is when you create a group to hold certain sheets. accessed from UI via right click, and choosing new sheet collection. however, the feature and the value seems working fine on my end.. I hope i didn't miss understood your question
verifying that via snoop
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Message 4 of 8
Sean_Page
@ricaun, I was using the image to show the Sheet Collection Name parameter wasn't in the list.
Message 5 of 8
Sean_Page
@Moustafa_K,
Yes, the collection themselves are working fine, but there is a Built In Parameter that is supposed to return the Name of the collection and that parameter doesn't seem to be working as it returns "null" like it isn't found.
Message 6 of 8
Moustafa_K
I just tried from C#
sheetView.get_Parameter(BuiltInParameter.SHEET_COLLECTION).AsValueString()
seems working fine still.
but yes SHEET_COLLECTIONNAME  returns null indeed
Moustafa Khalil
Message 7 of 8
ricaun
Is not showing because the SHEET_COLLECTION_NAME is not supported in that element type, the category sheet I guess.
I suppose the SHEET_COLLECTION_NAME parameter is used in the SHEET_COLLECTION element.
Snoop the SHEET_COLLECTION and check if is in there.
Message 8 of 8
Sean_Page
Boo, and duh all at the same time. Well, I would argue that it should be available on the sheet as well 🙂
Thanks Luiz!
