I'd like to share a simple Revit 2014 add-in that I've created with a friend of mine in another company accross town. What is the best way to zip or send him a file that he can double click and install it?
Could someone send me a website or place that I can do this?
Thank you.
Thank you.
Solved by jeremytammik. Go to Solution.
Dear Danny,
All you need to send him is the compiled .NET assembly DLL and the add-in manifest.
They have the filename extensions DLL and ADDIN, respectively.
They need to be placed in the appropriate Revit add-in folder.
More on this in the developer guide:
help.autodesk.com/view/RVT/2016/ENU > Developers > Revit API Developers Guide > Introduction > Add-In Integration > Add-in Registration.
This is explained in detail in the getting started material:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Cheers,
Jeremy
Dear Danny,
Cheers,
Jeremy
Thank you. I will give it a shot.
after receiving Dll files via email, make sure to unlock them:
http://thebuildingcoder.typepad.com/blog/2011/10/revit-add-in-file-load-exception.html
Revitalizer
Revitalizer
