Shadow amount of area object property like in Ecotectc
office
Observer Observer
office
Observer
Observer
Hello
we would like to calculate shadow percentage for each windows in building in 15 minutes interval and export it to file.
It was possible in Ecotectc software, but is it possible in other autodesk software too?
Best Regards
Paul Furtak
jeremytammik
Dear Paul,
Yes, absolutely.
In Revit, you could automate it by implementing an external event and triggering that in a 15-minute windows timer.
Then, use the best approach to determine the window area percentage and export that.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
office
Observer
Observer
Dear Jeremy
Thanks a lot!
We are software developer for building automation systems and our shutter control system for large buildings projects is using data generated by Ecotect software until now.
Now we have to realize the Vienna head office of siemens and need updated calculation software due the Ecotect limitations 😉.
I was a autolisp and arx developer many years ago and I need a little start help for Revit API. Do you have trainings or webinars about?
May I ask for small code example for my task : “use the best approach to determine the window area percentage”
Best regards | Freundliche Grüße
Paul Furtak
Managing Director | Geschäftsführer
NETxAutomation Software GmbH
Maria Theresia Strasse 41 - TOP 10
4600 Wels | Austria
Tel +43 7242 252900
[email protected]
www.netxautomation.com
[cid:[email protected]] [cid:[email protected]]
Member of: KNX Association | OPC Foundation | BACnet Interest Group Europe
Geschäftsführer: Pawel Furtak | USt.-ID: ATU61416408 | Firmenbuch-Nr: FN 258390k | FB-Gericht: Landesgericht Wels
jeremytammik
Dear Paul,
Cool that you worked with AutoLISP and ARX. So did I. Don't expect that to help you learn Revit programming, though.
The Revit API is very small and simple, with a twist.
The most important things to understand about of Revit programming are:
  • You need to understand the product first, from an end user point of view, or the API will make no sense at all.
  • Realise that the Revit API is entirely event driven. You can only use it in a valid Revit API context, and the valid context is only provided within the event handlers.
Here is everything you need to get started using the Revit API:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Here is everything you need to understand how to implement the external event:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.28
I suggest you start from that end and get hold of some sample models to test in.
Implement a dummy window area percentage calculator for starters.
Once you have that in place, ask a new question here in the forum about implementing the window area percentage calculator for real.
Before doing that, discuss with some application engineers and product usage experts how that calculation should be approached manually.
That will help decide how to address it programmatically.
Good luck, and have fun!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
office
Observer
Observer
Ok, thank you
Best Regards
Paul
