Setting a drawing scale to a view
I am trying to create a view in the revitapi (c#, 2019) and cannot set the drawing scale to it.
Any suggestions?
aignatovich
View has "Scale" property. Usually it is enough to set a value. The only problem could be if this value is controlled by view template.
ViewPlan viewPlan = ViewPlan.Create(currentDoc, viewFamilyType.Id, levelId);
Is the code I've used to create the view, how do I see the view template?
aignatovich
There are several options:
1) check viewFamilyType.DefaultTemplateId property
2) check viewPlan.ViewTemplateId property after a view plan was created
viewPlan.ViewTemplateId  - null
viewFamilyType.DefaultTemplateId - gives me an ID
How do I change the drawing scale knowing this?
Edit:
When i do try and set it, it says the parameter is read only.
aignatovich
if viewPlan.ViewTemplateId == ElementId.InvalidElementId just set viewPlan.Scale = 100 (for example)
In other cases, get view from ViewTemplateId:
var templateView = (View)doc.GetElement(viewPlan.ViewTemplateId);
then check this expression:
templateView.GetNonControlledTemplateParameterIds().Contains(ElementId(BuiltInParameter.VIEW_SCALE))
if is is true then you can set viewPlan.Scale = 100 otherwise you can't set it, because it is controlled by template
