How to run addin after Revit Command (opposite of PostCommand)?
ARX_AntonioCarneiro
ARX_AntonioCarneiro
Hi all.
I have developed a small addin that if invoked after creating a section opens its view. It is inelegant but effective: it filters the ids of the views and the greater is the last view created.
FilteredElementCollector elementos = new FilteredElementCollector(doc);
            ICollection<ElementId> elementosIds = elementos.OfCategory(BuiltInCategory.OST_Views).ToElementIds();
            List<int> idsNumero = new List<int>();
            foreach(ElementId e in elementosIds)
                idsNumero.Add(e.IntegerValue);
            int ultimo = idsNumero.Max();
            ElementId ultimoId = new ElementId(ultimo);
            View vistaNueva = doc.GetElement(ultimoId) as View;
            uidoc.ActiveView = vistaNueva;
            return Result.Succeeded;
The idea is that after executing the section command, the addin is automatically executed.
I need the opposite of PostCommand, first the command of Revit and then my code, is it possible?
Thanks 😉
aignatovich
Hi! It seems you can subscribe to DocumentChanged event instead. If some new section views were added, activate the last one.
MarryTookMyCoffe
yes, look on events in
Autodesk.Windows.ComponentManager
 .PreviewExecute - is before,
 ItemExecuted - after
do not worry it only gonna take Autodesk 5 years to fix bug
manuel.solis.lopez
Since you are not trying to modify the Revit Database, the best approach would be to subscribe an event handler method to the Application DocumentChanged event and use the Id of the new View to activate it.
Document.Application.DocumentChanged += (sender, args) =>
   if (args.Operation != Autodesk.Revit.DB.Events.UndoOperation.TransactionCommitted)
      return;
   var newElements = args.GetAddedElementIds();
   if (newElements.Count != 1)
      return;
   var doc = args.GetDocument();
   var view = doc.GetElement(newElements.First()) as ViewSection;
   if (view == null)
      return;
   var app = new Autodesk.Revit.UI.UIApplication(doc.Application);
   app.ActiveUIDocument.ActiveView = view;
Probably you would like to subscribe the event using an ExternalApplication in the OnStartup(...) method, in order to do it once when your addin is being loaded by Revit.
Regards.
