As the name suggests, I am trying to use the revit API to select specific elements which pass my filter. I am using the Selection.SetElementIds(ids) method to select the objects for the user to then isolate themselves or do further work.
The function appears to be working initially, as the elements are selected. However, there is no highlighting of the objects and if I were to click the isolate element button in the active view, they are not picked up by the command (I assume these two problems are linked).
Does anyone know why this is happening? I did a quick search through the forums and the only answer I could find was quite vague and had to do with "dockable panes". I am unaware of a workaround, any help would be greatly appreciated.
I have tested this is in both Revit 2017 and 2018 with similar results
Here is the code, I am implementing this using python and pyrevit:
# Get Document doc = __revit__.ActiveUIDocument.Document active_view = doc.ActiveView uidoc = UI.UIDocument(doc) #Set up lists in_place = [] ids = [] families = DB.FilteredElementCollector(doc).OfClass(DB.Family).ToElements() for family in families: if family.IsInPlace == True: ids.append(family.Id) #Convert list to ICollection ele_ids = List[DB.ElementId](ids) #Select + Isolate elements sel = uidoc.Selection.SetElementIds(ele_ids) uidoc.RefreshActiveView()
Update: I have done some fiddling around on my own and have managed to get the SetElementIds() method to work with highlighting when collecting Walls instead of in place families, which is what I was originally trying to isolate. Why would in place families not work but a typical element such as walls be highlighted?
"""Selects all in-place models in document""" from pyrevit import revit, DB, UI from pyrevit import forms from pyrevit import script from pyrevit import clr clr.AddReference("System") clr.AddReference("System.Core") from System.Collections.Generic import List from System.Collections.Generic import HashSet __author__ = 'Kai Zhu' __doc__ = 'This button finds all families within the document and highlights all instances which have been modelled in place' logger = script.get_logger() # Get Document doc = __revit__.ActiveUIDocument.Document active_view = doc.ActiveView uidoc = UI.UIDocument(doc) #Set up lists in_place = [] instance_symbol_ids = [] family_symbol_ids = [] #Get all families in doc families = DB.FilteredElementCollector(doc).OfClass(DB.Family).WhereElementIsNotElementType().ToElements() #Loop through families and test if they are in-place for family in families: if family.IsInPlace == True: family_symbol_ids.append(family.GetFamilySymbolIds()) in_place.append(family) #Collect all family instances family_instances = DB.FilteredElementCollector(doc).OfClass(DB.FamilyInstance).ToElements() #Set up list to select family instances in_place_instance = [] #Loop through instances and test if their type matches in-place set for instance in family_instances: instance_symbol_ids.append(instance.GetTypeId()) for symbol_set in family_symbol_ids: if symbol_set.Contains(instance.GetTypeId()): in_place_instance.append(instance.Id) #Convert list to ICollection ele_ids = List[DB.ElementId](in_place_instance) #Select instances to isolate sel = uidoc.Selection.SetElementIds(ele_ids) #Create transaction t = DB.Transaction(revit.doc, "Isolate Element") t.Start() #Temporarily isolate in-place family instances active_view.IsolateElementsTemporary(ele_ids) t.Commit()
