Set XYZ point for Model Group
Since we dont have a clean way of changing elements in a model group, i use the ungroup and re-group method. But when i re-group the XYZ point is placed in the center of the Model group. How could i change the XYZ point of a element?
mikako_harada
Hi Michal,
I think you are hitting a limitation of current API.
Here is the link to previous post:
http://forums.autodesk.com/t5/revit-api/group-origin-please-add-api-to-get-amp-set/m-p/5966829
Wish logged to the product team:
CF-3797
API ability to set origin point of group but not change location of the group itself
We recently started Idea Station for Revit:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent
You may want to vote/post the wish.  Exposing API for Group will be a good one; It will add more flexibility, I think.
Mikako Harada
Developer Technical Services
Here's the fix:
- Assign the new Group Type to the Group g.
- Call gtDup = g.GroupType.Duplicate("new group / group type name")
- Now assign the gtDup to the g Group and you have the correct XYZ, a new and fresh group. Without the need to ungroup and regroup.
renee.puusepp
Community Visitor
Community Visitor
Assigning a new GroupType to the group simply swaps the group, the original geometry is lost and the problem is not solved, in my opinion. But I may be missing something. Can anyone confirm that this solves the issue?
