Set Value of Cells in Key Schedule.
mohd.fadel
mohd.fadel
I am trying to create dynamically my schedule key. I have prepared the schedule with all its fields. However, the cells are still empty. I have created a program that would populate these values based on the user's intervention. This is the only link i found:
https://forums.autodesk.com/t5/revit-api-forum/add-a-row-to-a-schedule/td-p/7984145
Only when i run my add-in using the following code:
tsd.SetCellText(tsd.FirstRowNumber + 1, tsd.FirstColumnNumber, "HS1");
I get an InvalidOperationException saying that the operation is forbidden for cells in standard schedule body sections. Is this because i'm using Revit 2015?
Mohamad,
jeremytammik
Have you done your homework and searched this forum for existing solutions before asking your new question?
The documentation for the SetCellText method says:
Remarks
If this cell's type is not CellType.Text, and the operation is permitted on this cell, the cell type will be changed to type CellType.Text as a result of this call.
Exceptions
Exception Condition
Autodesk.Revit.Exceptions ArgumentException The given row number nRow is invalid. -or- The given column number nCol is invalid.
Autodesk.Revit.Exceptions ArgumentNullException A non-optional argument was NULL
Autodesk.Revit.Exceptions InvalidOperationException This operation is forbidden for cells in standard schedule body sections.
Jeremy Tammik
Developer Technical Services
The Building Coder
mohd.fadel
You are right. I saw it but didn't go through it till the end. I set it just like any other parameter.
Thank you, and sorry for the trouble.
