Problem with connector for DomainElectrical
ilgnv88
ilgnv88
I faced a situation where there is an electrical circuit, but the connectors do not see each other. Perhaps the matter is in the family, but then the question arises whether this is an isolated case or whether it is not entirely correct to determine the connection via connector.AllRefs. I used connector.AllRefs props and an error occurred to me in this case, when i to determine the connection through connector.AllRefs. It seems that in the electrical circuit of the basic equipment a connector is connected with DomainUndefined, which has a connector.AllRefs Other properties and methods for the connected and not connected connectors are the same.
Thanks a lot.
input -> collector.OfCategory(BuiltInCategory.OST_ElectricalCircuit).WhereElementIsNotElementType()
for element in input:
    for connector in (element.BaseEquipment.MEPModel.ConnectorManager.Connectors):
reflist
= [x for x in connector.AllRefs] if ("DomainElectrical" in str(connector.Domain)) and ("PowerCircuit" in str(connector.ElectricalSystemType)) and reflist:
jeremytammik
Does the connection work well manually in the user interface?
Jeremy Tammik
Developer Technical Services
The Building Coder
ilgnv88
Hi, Jeremy. Thanks for your soon reply. This is a video demostrate our process
https://www.dropbox.com/s/b8cbqmsfxa68ydi/%D0%9D%D0%BE%D0%B2%D0%B8%D0%BA%D0%BE%D0%B2%20%D0%90%D0%BB%...
ilgnv88
ilgnv88
Simulated a situation in Revit2020. May be problem in the family..
https://www.dropbox.com/s/8z8zpl1h8kh459d/progect1.rvt?dl=0
ilgnv88
