Set Layout as fixed number for Triangular pile cap
hossam.amer666
Message 1 of 9
hossam.amer666
Hello All,
I'm trying to reinforce pule cap using revit api. I managed to create rebar set for rectangular pile cap using rebar.GetShapeDrivenAccessor().SetLayoutAsFixedNumber but I can't do that with triangular pile cap.
I know about varying rebar set in revit but I can't do it in revit api.
i searched alot but I found nothing so any kind of help would be great
Replies (8)
Message 2 of 9
jeremy_tammik
I asked the development team for you...
Message 3 of 9
Organon
@hossam.amer666,
Try this:
rebar.DistributionType = DistributionType.VaryingLength;
Arquitectura | Análisis CAD & BIM | Diseño Paramétrico | Programación
BIM-METADATA | LinkedIn | YouTube
Message 4 of 9
hossam.amerUY9KR
I'm still waiting for your answer, jeremy
Message 5 of 9
hossam.amer666
It worked but as shown. do toy suggest any way to handle this ?
Message 6 of 9
jeremy_tammik
I am also still waiting for an answer from the development team. I re-prompted them now.
Meanwhile, I am assuming that you can solve this manually in the end user interface. Can you confirm and explain how, please? Thank you!
If not, the API will probably not enable it either.
Message 7 of 9
Organon
@hossam.amer666,
In this case, you can create 2 rebars sets:
Message 8 of 9
hossam.amerUY9KR
It could be done manually by creating free form rebar and distribution type is surface
Message 9 of 9
jeremy_tammik
The development team say:
There's no way to reinforce the pile in his picture with only one varying shape driven rebar set because the start/end bar handles can be constrained to only one surface -- in his picture, the angled one.
To create free form rebar from the API you have 2 options:
1) Just provide a list of curves, a valid host and a bar type. This will create a Free form rebar that it will be inert, not reacting to any host modifications -- it won't have constraints.
2) In addition to the valid host and the bar type, provide a GUID to an implementation of IRebarUpdateServer. The developer will be responsible to basically create its own logic to: create rebar handles, constrain them and generate rebar curves based on the regeneration of the constraints references.
I hope this helps.
