Set Global Parameter value
Message 1 of 9
Hello everyone.
I'm trying to apply a value to a Global Parameter. Can anyone tell me why the follwing code doesn't work:
double value = 55;
ElementId paramId = GlobalParametersManager.FindByName(doc, "ParameterName");
GlobalParameter param = doc.GetElement(variable) as GlobalParameter;
paramSetValue(new DoubleParameterValue(value));
Thank you
Replies (8)
Message 2 of 9
jeremytammik
Yes. The variable variable is not set.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 9
GonçaloFeio1321
Please tell what went wrong, what exception was thrown.
paramId returnsInvalidElementId if no GlobalParameter is found with that name.
Then, param.SetValue should had worked.
Message 4 of 9
The parameter does exists on file.
Please check the image bellow to see the exception message.
Message 5 of 9
Can you tell me how to solve it please?
Message 6 of 9
matthew_taylor
Hi @Anonymous
There's a pretty decent example here:
http://www.revitapidocs.com/2016/df012c22-6e65-8de5-1057-f15660d02288.htm
There are also a lot of notes that look worth reading here:
http://www.revitapidocs.com/2016/b0e53a4a-84ad-abb4-358d-9797870f101b.htm
Also, your quasi-code has a couple of issues. (A missing period, inconsistent variable naming.) I wonder whether one of those are your actual problem?
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Message 7 of 9
matthew_taylor
Sounds like you just need a valid transaction. There's an example of that in the links I provided.
Cheers,
-Matt
Message 8 of 9
Sorry, as Jeremy said there is an error in the code i've pasted above but the problem stills the same:
double value = 55;
GlobalParameter param = doc.GetElement(paramId) as GlobalParameter;
Message 9 of 9
GonçaloFeio1321
@matthew_taylor already answered. You need a started Transaction.
