Set Floor Span Direction Symbol
mphelt
mphelt
Is there any chance to create or otherwise set Span Direction Symbol for Floor?
I create Floor using Create.NewFloor and then set Floor.SpanDirectionAngle property.
But doing this, when I try to manually edit sketch from the UI, I can't see the span direction symbol anywhere.
How to achieve that?
Joe.Ye
Hi there,
Not sure what's cause.
The following code can successfully create a floor and set the span direction. After creating the floor, and edit the floor, I can see the span symbol in the floor editor.
Here is the code.
<code>
using System;
using System.Collections.Generic;
using System.Text;
using System.Windows.Forms;
using Autodesk.Revit .DB;
using Autodesk.Revit.UI;
using Autodesk.Revit .ApplicationServices;
using Autodesk.Revit.Attributes ;
using Autodesk.Revit.UI.Selection;
[TransactionAttribute(TransactionMode.Manual)]
public class RevitCommand : IExternalCommand
public Result Execute(ExternalCommandData commandData,
ref string messages, ElementSet elements)
UIApplication app = commandData.Application;
Document doc = app.ActiveUIDocument.Document;
Transaction trans = new Transaction(doc);
trans.Start("CreateFloorChangeSpanDirection");
//create a floor.
CurveArray ca = new CurveArray();
double width = 5;
Line l1 = Line.CreateBound(new XYZ(width, width, 0), new XYZ(width, -width, 0));
Line l2 = Line.CreateBound(new XYZ(width, -width, 0), new XYZ(-width, -width, 0));
Line l3 = Line.CreateBound(new XYZ(-width, -width, 0), new XYZ(-width, width, 0));
Line l4 = Line.CreateBound(new XYZ(-width, width, 0), new XYZ(width, width, 0));
ca.Append(l1);
ca.Append(l2);
ca.Append(l3);
ca.Append(l4);
Floor f = doc.Create.NewFloor(ca, false);
f.SpanDirectionAngle = 0;
trans.Commit();
return Result.Succeeded ;
<code>
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
ellen.cummings
We are currently experiencing the same issue.
If you try a non-zero value then the Structural Floor Span Direction does not seem to be set when you attempt to edit the slab geometry (Modify > Edit Boundary > Select green tick without making any changes) - see error that occurs in screenshot below.
Please note that when you show the slab direction using Annotate > Span Direction > Auto place ON, the span direction symbols are added as you would expect. Span Direction.JPG
abdelrahmanfathe95
spanDirection is not set set in the scketch plane when changing SpanDirectionAngle property.
RPTHOMAS108
Yes seems like an error. However as a workaround if you change the span direction in a separate transaction after creating the slab then the span direction line is correctly created (use of a subtransaction doesn't resolve the issue in the same way).
This is a rare example of being able to do something in the API that you can't do in the UI i.e. complete a slab sketch without a span direction line.
Public Function TObj105(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
        Dim Doc As Document = commandData.Application.ActiveUIDocument.Document
        Dim UIDoc As UIDocument = commandData.Application.ActiveUIDocument
        Dim Width As Double = 10
        Dim LN1 As Line = Line.CreateBound(New XYZ(Width, Width, 0), New XYZ(Width, -Width, 0))
        Dim LN2 As Line = Line.CreateBound(New XYZ(Width, -Width, 0), New XYZ(-Width, -Width, 0))
        Dim LN3 As Line = Line.CreateBound(New XYZ(-Width, -Width, 0), New XYZ(-Width, Width, 0))
        Dim LN4 As Line = Line.CreateBound(New XYZ(-Width, Width, 0), New XYZ(Width, Width, 0))
        Dim CA As New CurveArray
        CA.Append(LN1)
        CA.Append(LN2)
        CA.Append(LN3)
        CA.Append(LN4)
        Dim Flr As Floor = Nothing
        Using Tx As New Transaction(Doc, "Floor")
            If Tx.Start = TransactionStatus.Started Then
                Flr = Doc.Create.NewFloor(CA, True)
                Tx.Commit()
            End If
        End Using
        If Flr Is Nothing = False Then
            Using Tx1 As New Transaction(Doc, "Add span direction")
                If Tx1.Start = TransactionStatus.Started Then
                    Flr.SpanDirectionAngle = Math.PI / 4
                    Tx1.Commit()
                End If
            End Using
        End If
        Return Result.Succeeded
    End Function
abdelrahmanfathe95
Thanks, so much you really saved my day today.
