Set Ceiling width value
miguelBW5DE
miguelBW5DE
Greetings from perú!
For this opportunity, I'm looking to change the ceiling thickness:
so far I've managed to get the width value but I still confused about the appropriate syntax to change the width value:
			List<HostObjAttributes> ceilings = new FilteredElementCollector(doc).WhereElementIsElementType().OfCategory(BuiltInCategory.OST_Ceilings).Cast<HostObjAttributes>().Where(ceiling=>ceiling.GetCompoundStructure() != null).ToList();
			foreach (HostObjAttributes ceiling in ceilings) {
				//stb.AppendLine(ceiling.Name);
				if (ceiling.Name =="Soffit Only Above Cabinets - H10\"") {
					IList<CompoundStructureLayer> layers = ceiling.GetCompoundStructure().GetLayers();
					foreach (var layer in layers) {
						layer.Width = 3;
After running the script, the ceiling thickness does not change. I would appreciate some help on this one. Thanks in advance.
Best regards,
Miguel G
RPTHOMAS108
Where there is a Get there is usually a Set.
The Get returns a detached copy which you need to return back with changes made, you have two 'Gets' there in the above.
So you have various 'Sets' also for your 3-foot-deep ceiling layer to take effect:
CompoundStructure.SetLayers
or perhaps
CompoundStructure.SetLayerWidth
then
HostObjAttributes.SetCompoundStructure
miguelBW5DE
Hi Richard, nice to hear from you again. Thanks for your prompt reply. I even tried this syntax and do not work at all:
					CompoundStructure compStr = ceiling.GetCompoundStructure();
					int indexCore = compStr.GetFirstCoreLayerIndex();
					compStr.SetLayerWidth(indexCore,7);
					stb.AppendLine(indexCore.ToString());
I will check out what you have suggested right now
miguelBW5DE
Thank you Richard you are the boss! what I was missing in the last portion of code was " ceiling.SetCompoundStructure(compStr);"
All the best!
Miguel G.
