Sensor detection area 3D
MatthiasWyss
MatthiasWyss
Hi all
I'm trying to display the detection area of motion and presence sensors in a 3D view.
So far the only possibility I found was to use DirectShapes to do so but then I end up with a "physical" geometry.
Is there another way to do this with some kind of "virtual" geometry?
The attached image shows one example of such a sensor. Even though this one is rotationally symmetric not all of them are. They can have very complex forms.
Best
Matthias
jeremytammik
Dear Matthias,
You can display analysis results such as those you describe using the AVF, the analysis visualisation framework:
https://thebuildingcoder.typepad.com/blog/avf
For instance, I used it in my RvtFader add-in to display signal attenuation in a building as a heatmap on the floor:
https://github.com/jeremytammik/RvtFader
https://thebuildingcoder.typepad.com/blog/2017/03/rvtfader-avf-ray-tracing-and-signal-attenuation.ht...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
MatthiasWyss
Dear Jeremy,
thanks a lot for your reply and the hint with the analysis framework.
I tried the AVF to display the detection are but I could manage to make it look as expected.
So I tried to create a transient DirectShape but this didn't show up in the view.
Finally I found your post in this forum that this function shouldn't be used.
https://forums.autodesk.com/t5/revit-api-forum/document-maketransientelements/td-p/7774471
Is there another possibility to create transient DirectShapes? Basically I just don't want the DirectShape to be stored in the project.
Best
Matthias
jeremytammik
Dear Matthias,
Thank you for your appreciation.
Nope, sorry, the direct shape is a database element and needs to be stored in the database.
The simplest approach to achieve what you are asking for that I can think of is to create direct shapes, tag them, and subscribe to the DocumentSaving event to remove them again before the document is saved.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
MatthiasWyss
Ah, great idea, thanks Jeremy!
I didn't think of that!
Best
Matthias
