Selecting the wall based on geometry
Hello everyone,
Is it possible to select a wall part using dynamo, based on its geometry? I need to select the outer part of the wall in a more automated way. Do you have any suggestion?
Thanks in advance
jeremytammik
The Revit API PickObject function enables you to specify the object types allowed to be selected during selection operations:
https://www.revitapidocs.com/2020/2d0cbbba-d4ab-84b7-b081-36c14769d82c.htm
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
