SectionProperty as Dimension lable failed
net.k.kiselev
net.k.kiselev
Hello i want assign some parameters as dimension label. It's work fine for common parameters i use:
dim.FamilyLabel = param;
But if parameter type is SectionProperty, its approach invoke this exception:
Autodesk.Revit.Exceptions.ArgumentException: The parameter's ParameterType is not the correct type for this dimension.
But manually i can use such parameters as label. Maybe Revit API have another approach for such parameters?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi  @net.k.kiselev ,
I don't see any such problem.
Here is the code I used.
Dimension dimension;
FamilyParameter famParam = doc.FamilyManager.AddParameter("Parameter Name", BuiltInParameterGroup.PG_IDENTITY_DATA, ParameterType.SectionProperty,true);
dimension.FamilyLabel =famParam;
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
net.k.kiselev
I test it in another versions, it not work in 2019 Revit version, but in 2020 work.
