I would like to ask you if it is possible to create script for multiple sheet printing directly from Revit on plotter.
I use to insert 4 types of paper roll into my Canon IPF770 plotter - 297mm, 420mm, 594mm and 914mm.
For every sheet/layout in AutoCAD I set up size in "Page Setup Manager".
Then I insert paper roll with height of 297mm into my plotter, click on "batch plot" select all sheets with "297" in name, change "Publish To": "Plotter named in page setup", change how many copies I want to print and click on publish.
Thanks to this approach I can directly print all my sheets with height of 297mm on my plotter (no matter what is the lenght of my sheets).
I do the same for my sheets of height 420, 594 and 914mm.
It means I can print directly from AutoCAD to my plotter multiple sheets in multiple coppies I need.
In Revit there is no "page setup manager" so I have no option to set it up and then print. Revit sheet size is bounded by (for isntance) rectangle of my sheet edges. When I export to PDF, Revit can auto detect this size of my sheet and create PDF correctly by that size. However, when I want to print directly on my plotter, there is no option to set up "auto detect Revit sheet size" on my plotter.
Is it possible to have a script that can set this up correctly please ? To achieve that I insert my 297mm paper roll into my plotter and print all my sheets which height is 297mm no matter what lenght of those sheets is ?
Thank you in advance
Not sure if I was able to comprehend your needs correctly, so you want to print in a group of sheets that have similar Height or width (depending on the orientation) ?
see if the below might help.
Have you tried PageSize property in PrintSettings?
a very minimal example Code:
var printManager = Doc.PrintManager;
var printSet = printManager.PrintSetup.CurrentPrintSetting;
printSet.PrintParameters.PaperSize = printManager
.PaperSizes.OfType<PaperSize>()
.First(o => o.Name == "A3");
you also have view ViewSheetSetting, by which you can use to group all sheets of the sizes you prefer to print in a batch, similarly to what you experienced in CAD
printManager.ViewSheetSetting
Interested in batch processing, scripting, automatically handling multiple documents? Have you checked the RBP?
