Scope box in IFC export
r.schrooijen
r.schrooijen
Community Visitor
Community Visitor
Hi all,
I've got a problem when i export a ifc. The scope boxes and Reference planes that are standerd in a template keep showing up when I load the ifc back into Revit (2024).
In the ifc option scope boxes turned to Not Exported
I export with only elements visible in view ON. and the scope box not visible.
I deleted all the scope boxes and lines in the template before project use.
When i put my own scopebox in and link levels to that box its is not exported neat in line with the scope box  perimeter.
I work with a lot of 3de party ifc's and see it a lot. But not with all.
So what am I doing wrong?
thank you
jeremy_tammik
For IFC-specific questions, you may have better luck in the IFC discussion forum:
TripleM-Dev.net
Best to post this in the Revit Architecture Forum.
But this is easy to solve, if not Revit Template is defined for IFC Link/open the default Revit template (the first one in the list) defined in revit is used. (in File > Options > File locations > Project templates)
To set another (completly empty template) go to File > Open > IFC options; in the "Default Templates for IFC Import" option box fill in the path to the template that should be used. If this box is empty the default template is used.
- Michel
Note that this IFC default template should not be changed if the Linked IFC is dimensioned or tagged etc, otherwise during a update of the IFC they can be lost. With linking a IFC revit tries to maintain the elementId, but if the template is changed those may already be used and a updated IFC id's will change and any references to the Linked IFC will be lost or worse jump to other elements!
