Schema entity disappears when changing group offset or level.
frte
frte
When changing "Reference Level" or "Origin Level Offset", my entity is getting deleted from the group. From Revit DB snoop i can see that before i alter these parameters, my entity is there, as seen in the picture below.
After changing any of the two parameters, the result is as follows:
As you can see the entity with schema "Connection" is gone.
Am I doing something wrong or is this a bug/intensional behaviour of Revit?
Regards
frte
I've done some more testing and I have found out that when changing one of these parameters, instead of moving the group, a new group is created.
The result is a new ids(Id and uniqueId) and extensible storages is erased.
I have a workaround for this when moving it using the API, but my concern is when a user changes one of these parameters. My addin is dependent on consistent uniqueId and that the extensible storage entities don't get erased.
eason.kangEDLV4
Autodesk Support
Autodesk Support
Please accept our sincere apologies for the late reply, this case is logged as REVIT-128235 with our development team for this on your behalf as it requires further exploration and possibly a modification to our software. Please make a note of this number for future reference. You are welcome to request an update on the status of this issue or to provide additional information on it at any time quoting this change request number.
Eason Kang
Developer Advocate
Developer Advocacy & Support Service
Autodesk Platform Service (formerly Forge)
Hello.
It's been a while since this post, but recently I'm having this problem.
Have you solved this problem?
