Schedules for sheet revisions with company's specific parameters added.
Hi all
I recently started exploring the Revit API and my first question here concerns what is possible regarding customization of a revision schedule; the one found in title blocks of drawing sheets.
My company’s standards prescribe that fields for initials of designer, reviewer and approver should be attached to each record in a revision table, in addition to parameters available within the standard Revit revision schedule.
I know the API documentation says that if you can do it in the UI then it’s possible in the API. Instead of spending hours or days seeking a solution that maybe doesn’t exists it is wiser to try asking you guys.
Is it possible, while taking advantage of the revision functionality within Revit, to produce and place a revision(/custom) schedule on drawings, containing the additional fields/parameters as described above?
From what I have studied there are multiple ways to add parameters to the model and schedules can be created without referring to a specific category. I was hoping that somehow combining various features of the API would enable a reasonable good workaround. Has anyone tried something similar and managed to build such a schedule and show it on the respective drawing?
Sigurjón
