Save modification document , and make active document to unactive
dor_r
dor_r
I am trying save the active document when the file is in modification
and i get this error  "Operation is not permitted when there is any open sub-transaction, transaction, or transaction group."
How can i prevent this error?
And how can i make my activeuidDocument to be unactive?
jeremytammik
Dear Dor,
Thank you for your query.
It is a bit weird.
Normally, this message would only be produced if you have started a transaction in your external command and not terminated it.
You can terminate it either by committing it, or rolling back the changes.
Here is more on the topic of transaction handling:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.53
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
dor_r
Thanks for your answer
I found the open transaction.
About the second question
How can I make the active document to unactive?
jeremytammik
Dear Dor,
Thank you for your update and appreciation.
I am glad it helped.
The only way to make a document inactive that I can think of is to activate another one instead.
This can be achieved, e.g., using OpenAndActivateDocument:
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
dor_r
First of all let me say thank you for the response.
If I want to close the active document
and open the main page of Revit
(i don`t want to open another one)
how can i do that?
dor_r
I want to go to the main screen (see attached picture)
From the active documen
How can i do that?
thanks
