Hi all, not very Revit API specific but I'll give it a try anyway. I'm following a discussion here https://forums.autodesk.com/t5/revit-api-forum/example-rubberband/m-p/9004118#M41057 but apparently I'm getting error when I copy the code, any idea how to fix it? PS I don't have experience with VB, Ill use the code as it is. Cheers!
Imports System.Runtime.InteropServices
Public Module WindowsMessaging
<DllImport("user32.dll", EntryPoint:="SendMessage")="">
Function SendMessage(ByVal hWnd As Integer, ByVal Msg As Integer, ByVal wParam As Integer, ByVal lParam As Integer) As Integer</dllimport("user32.dll",>
End Function
<DllImport("user32.dll", EntryPoint:="PostMessage")="">
Function PostMessage(ByVal hWnd As Integer, ByVal Msg As Integer, ByVal wParam As Integer, ByVal lParam As Integer) As Integer</dllimport("user32.dll",>
End Function
Public Const WM_KEYDOWN As Integer = &H100
Function SendWindowsMessage(ByVal hWnd As Integer, ByVal Msg As Integer, ByVal wParam As Integer, ByVal lParam As Integer) As Integer
Dim result As Integer = 0
If hWnd > 0 Then result = SendMessage(hWnd, Msg, wParam, lParam)
Return result
End Function
Function PostWindowsMessage(ByVal hWnd As Integer, ByVal Msg As Integer, ByVal wParam As Integer, ByVal lParam As Integer) As Integer
If hWnd > 0 Then result = PostMessage(hWnd, Msg, wParam, lParam)
Return result
End Function
End Module
error
It's a simple syntax error. Apparently some editor confused Visual Basic attributes with xml. Here's the fixed code.
<DllImport("user32.dll", EntryPoint:="SendMessage")>
End Function
<DllImport("user32.dll", EntryPoint:="PostMessage")>
End Function
Return result
End Function
Return result
End Function
End Module
However, I am skeptical of declaring hWnd, wParam, and lParam as Integers when running in 64 bits. I'd probably declare them as IntPtrs.
