Rotation in slope
Rotation in slope
nitinjambhale
Rotation in slope
nitinjambhale
Hello friends,
I m struggling to rotate a family in slope.
Please help.
Thanks.
-Nitin.
Dear Friend,
I am manish i am facing same problem in rotation of families.
while i am using
ElementTransformUtils.RotateElementDocument,Family Id, axis, Rotation Angle);
I am not Getting that
1. How to calculate Axis.
2. Rotation angle.
Joe.Ye
Hi Nitin,
Here is a sample showing how to rotate an element.
public void RotateColumn(Autodesk.Revit.DB.Document document, Autodesk.Revit.DB.Element element)
    XYZ point1 = new XYZ(10, 20, 0);
    XYZ point2 = new XYZ(10, 20, 30);
    // The axis should be a bound line.
    Line axis = document.Application.Create.NewLineBound(point1, point2);
    ElementTransformUtils.RotateElement(document, element.Id, axis, Math.PI / 3.0);
What's problem when rotate the sloped family? Please give more detailed information about what kind of element?   It is better to upload a very simple model to explain how to you want to rotate it.
BTW, if you just want to rotate a sloped column, you can change the column's "Cross-Section Rotation"  parameter value to rotate the column.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
nitinjambhale
HI joe
Thanks for the reply. Its working now. There was some misunderstanding.
Thanks.
-Nitin
