Rotation from a LocationCurve
I am currently putting together a builderswork utility based on intersections of architectural walls and floors and have ran into issues with services intersecting with floors on a vertical (Z Axis) due to not being able to get the rotation of the service.
Been looking through sources online for a solution and unable to find one, so looking for some help from some people who can assist and hopefully a solution.
Currently I know that getting the rotation from a FamilyInstance can be obtained by casting the (FamilyInstance.Location as LocationPoint).Rotation
How would I obtain the rotation from an Element that can only be cast into a LocationCurve? (like duct, pipe, conduit, etc)
Would it be through the Transform class somehow by using XYZ.BasisZ.AngleTo()?
Example picture of what angle information i'm trying to retrieve from a duct run that's vertical.
After a lot playing around and continued research I came up with a solution to getting the angle from above by using the MEPCurve -> ConnectionManager -> Connectors -> CoordinateSystem and performing Asin to return the Radians in a minus or positive value, allowing the builderswork GenericModel family to be placed and rotated by the radians.
public double GetAngleFromMEPCurve(MEPCurve curve)
     foreach (Connector c in curve.ConnectorManager.Connectors)
          return Math.Asin(c.CoordinateSystem.BasisY.X);
     return 0;
If anyone can think of a better solution to it over the next 24 hours i'd love to hear from them, after that I will accept this as the correct answer and mark as the solution.
