- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I was just working with Scope Boxes in Revit 2022 [ 2022 22.0.2.392 20210224_1515(x64) ] and noticed rotating the element via the Rotate tool causes the Name parameter to be changed. This was causing an error with my current coding project, which I can work around but thought I'd check if anyone else can replicate this error.
Seems to be fixed in updated versions of Revit on other peoples PC's here in the office so I will just update my software now, so this post is more of an FYI for the Dev Team.
Cheers,
Ewan
Autodesk ITF 2018-2020 / Senior Project Drafter / Technical & Computational Modelling Specialist / Dynamo Enthusiast
Developer Advocacy and Support,
