Rotating Assembly View
shevyakov.a
Message 1 of 10
shevyakov.a
Hi guys!
I have hard times rotating views in Revit 2019.
I've got assemblies in my project that are faced to different directions (N,S,E,W. We can assume, that absolute values of ( X , Y ) are either (0,1) or (1,0) )
With single transaction I create multiple sheets with views on them. I try to rotate the view using the subtransaction (it might be the issue).
Initial call:
 using (transaction)
                List<ViewSheet> sheets = new List<ViewSheet>();
                transaction.Start();
                Utility.Sheets.CreateSheets(Document, elementId, 9, out sheets);
                //Creating sheets and views
                //sheet 1
                Utility.Sheets.Create3DSheet(Document, elementId, sheets[0]);
                //sheet 2
                Utility.Sheets.CreateCasingDrawing(Document, elementId, sheets[1]);
                //sheet 3
                Document.Regenerate();
                transaction.Commit();
                for (int i = 0; i < sheets.Count; i++)
                    Utility.Sheets.SetSheetParameters(Document, elementId, sheets[i], i+1);
code snippet from Utility.Sheets.CreateCasingDrawing
ViewSection vsFront2 = AssemblyViewUtils.CreateDetailSection(document, id, orientations[0], viewFront, isAssigned: true);
            ViewSection vsUp2 = AssemblyViewUtils.CreateDetailSection(document, id, AssemblyDetailViewOrientation.HorizontalDetail, viewSection, isAssigned: true);
            ViewSection vsLeft2 = AssemblyViewUtils.CreateDetailSection(document, id, orientations[2], viewSection, isAssigned: true);
            ViewSchedule matSched2 = AssemblyViewUtils.CreateSingleCategorySchedule(document, id, scheduleCategoryId: schedTypeElement.Category.Id, schedule, isAssigned: true);
            Viewport.Create(document, sheet.Id, vsFront2.Id, new XYZ(-0.75459, 0.63812, -0.241));
            Viewport.Create(document, sheet.Id, vsUp2.Id, new XYZ(-0.75459, 0.259682048822124, -0.351351502340035));
            Utility.Sheets.RotateHorizontalView(document, vsUp2, orientations[0]);
            Viewport.Create(document, sheet.Id, vsLeft2.Id, new XYZ(-0.108762048822124, 0.634839160104988, -0.225465616797901));
Utility.Sheets.RotateHorizontalView is supposed to do the trick by analyzing the assembly orientation and rotating the Plan view accordingly.
So far, I've tried 3 solutions:
1. Directly setting the Cropbox.Transform properties. Ain't working, just like the docs state. (Why do they have public setter though?)
2. https://thebuildingcoder.typepad.com/blog/2013/09/rotating-a-plan-view.html Seems like the thing I'm looking for, except there's no Cropbox Element in Revit 2019. Throws a NullReferenceException, as expected
3. I've modified the 2nd solution and now I'm trying to rotate the OST_Viewer. It executes, though the result is completely different from what I expect.
Here're code samples with the results:
Var 1:
SubTransaction rotation = new SubTransaction(document);
            Transform transform = view.CropBox.Transform;
            rotation.Start();
            view.CropBoxActive = true;
            rotation.Commit();
            rotation.Start();
            if (orientation == AssemblyDetailViewOrientation.ElevationLeft)
                transform.BasisX = new XYZ(0, -1, 0);
                transform.BasisY = new XYZ(1, 0, 0);
            if (orientation == AssemblyDetailViewOrientation.ElevationRight)
                transform.BasisX = new XYZ(0, 1, 0);
            if (orientation == AssemblyDetailViewOrientation.ElevationBack)
                transform.BasisX = new XYZ(-1, 0, 0);
                transform.BasisY = new XYZ(0, -1, 0);
            rotation.Commit();
            rotation.Start();
            view.CropBoxActive = false;
            rotation.Commit();
Result:
(the front view is ok, the cropbox has been activated and not deactivated)
Var3:
            //Var 3
            Element cropBoxElement = new FilteredElementCollector(document, view.Id).OfCategory(BuiltInCategory.OST_Viewers).FirstElement();
            XYZ top = view.CropBox.Max;
            XYZ bottom = view.CropBox.Min;
            XYZ center = 0.5 * (bottom + top);
            XYZ centerPlus = new XYZ(center.X, center.Y, center.Z + 1);
            Line axis = Line.CreateBound(center, centerPlus);
            rotation.Start();
                angle = System.Math.PI / 2;
                angle = 3 * System.Math.PI / 2;
                angle = System.Math.PI;
            ElementTransformUtils.RotateElement(document, cropBoxElement.Id, axis, angle);
            rotation.Commit();
Result:
(Instead of the plan, the front view has been transformed)
What am I doing wrong? What might be the issue?
I'm clearly making a mistake, I cannot see.
Thanks in advance!
Replies (9)
Message 2 of 10
jeremy_tammik
Have you tried using the view UpDirection property?
https://www.revitapidocs.com/2022/f93840a2-e22b-937f-a10b-a379ebbb2375.htm
Message 3 of 10
shevyakov.a
It seems I don't quite get how I can use the readonly property in this case 😞
All of the created plan views have identical UpDirection value,
Direct setting them will cause compilation error,
Using its value to rotate OST_Viewer does no good (as, basically any other rotation).
What I'm trying to do now is reconsidering call hierarchy in my program to rotate OST_Viewer after commiting main transaction , not opening a subtransaction. But I don't know whether it is going to help.
And I still do not have a mere idea where to use UpDirection (if not in calculating rotation axis)
Message 4 of 10
jeremy_tammik
Oh dear. Maybe it can only be set in 3D views.
Message 5 of 10
shevyakov.a
Well, maybe, but I'm confused about the way I should use it
Let me ask a simpler question:
What object (type or category) do I have to access to rotate assembly plan view?
Can you advise any SDK samples with a similar problem? (Simple "RotateFramingObject" rotates element, not the view)
Message 6 of 10
jeremy_tammik
First of all, you need to know how to solve this manually in the end user interface. And, above all, is it possible at all? If not, then the API will hardly support it either.
Message 7 of 10
shevyakov.a
Excuse me for taking this much time to respond
That's how I do it in Revit user interface:
1. Open a OST_Viewport Element to select the corresponding ViewSection
2. Make Cropbox visible
3. Plain rotate Cropbox ('RO' hotkey)
4. Make Cropbox invisible again, close OST_Viewport
and here's the issue I have:
1. Direct setting of View.Cropbox.Transform is ignored, according to documentation
(https://www.revitapidocs.com/2019/d6246051-ecfb-7388-0429-6ed65de72638.htm)
2. I can't possibly set another properties like View.ViewDirection or View.UpDirection because they don't have public setters
3. Passing the Cropbox Element (OST_Viewer category) into ElementTransformUtils.RotateElement() returns Rotation of OST_Viewport Element instead (initial post -> var3 -> result)
So far, I've been unable to solve this on my own 😞
Message 8 of 10
shevyakov.a
Figured it out, finally!
Missed some important details 'bout creating multiple sections, cropbox visibility etc.
Message 9 of 10
jeremy_tammik
Congratulations on solving it!
Would you like to share the working code?
Message 10 of 10
shevyakov.a
Yep. It's not a big deal, actually) Hopefully, it will help someone)
/// <summary>
        /// Method for rotating plan view.
        /// It rotates plan view according to the Front view orientation
        /// </summary>
        /// <param name="document">Active runtime document</param>
        /// <param name="viewSection">View to rotate</param>
        /// <param name="orientation">Front view orientation</param>
        public static void RotatePlanView(Document document, ViewSection viewSection, AssemblyDetailViewOrientation orientation)
            View view = (View)viewSection;
            double rotationalAngle = 0;
            string horizontalViewName = "sampleName";
            //we're working inside an ongoing transaction, so we're creating a subtransaction
            //The following FilteredElementCollector overload searches for visible elements.
            //The CropBox is invisible by default, so, we have to set visibility first
            rotation.Start();
            view.CropBoxVisible = true;
            rotation.Commit();
            //We select the cropbox element.
            IList<Element> visibleElementsOnView = new FilteredElementCollector(document, view.Id).OfCategory(BuiltInCategory.OST_Viewers).WhereElementIsNotElementType().ToElements();
            Element cropBoxElement = visibleElementsOnView.Where(o => o.Name == horizontalViewName).FirstOrDefault();
            //We are about to rotate plan view in XY plane about the cropbox center
            BoundingBoxXYZ cropBoxBounding = cropBoxElement.get_BoundingBox(view);
            XYZ top = cropBoxBounding.Max;
            XYZ bottom = cropBoxBounding.Min;
            XYZ cropBoxCenter = 0.5 * (bottom + top);
            XYZ cropBoxCenterUp = new XYZ(cropBoxCenter.X, cropBoxCenter.Y, cropBoxCenter.Z + 1 );
            Line rotationalAxis = Line.CreateBound(cropBoxCenter, cropBoxCenterUp);
            //Just choosing the proper angle and perform rotation
            rotation.Start();
                rotationalAngle = (System.Math.PI / 2);
            else if (orientation == AssemblyDetailViewOrientation.ElevationRight)
                rotationalAngle = (3 * System.Math.PI / 2);
            else if (orientation == AssemblyDetailViewOrientation.ElevationBack)
                rotationalAngle = System.Math.PI;
            ElementTransformUtils.RotateElement(document, cropBoxElement.Id, rotationalAxis, rotationalAngle);
            rotation.Commit();
            //Setting cropbox visibility back to defaults
            rotation.Start();
            view.CropBoxVisible = false;
            rotation.Commit();
