Rotate Project North
H.echeva
H.echeva
Is there a way to rotate the project north with the API?
Note that I am not talking about the true north or creating new positions. Also, I am not talking about changing the Project Base Point's angle to true north;  I need the equivalent of rotating the project north that you find in the UI, which in reality rotates all the elements in the project.
I know this is not recommended, however, I need it.
Any suggestions are welcome.
Many thanks
scgq425
Hi @H.echeva :
Yes , this not recommand in Revit , if u want to rotate all element to the real north , you can link this project to a new empty project , and unlink the project , use this you can rotate all elements
if u want change this element in project , is cant . in fact many element has host or reference , or somelike floor need to get rotate-axis etc , is so complex.
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
