Difference in gbxml export with analysis mode "Use Rooms Or Spaces" with Revit API and Revit UI 2024
khagesh_mahajan
Message 1 of 1
khagesh_mahajan
When we create energy model from Revit UI using energy data setting of analysis mode "Use Room Or Spaces" and run the system analysis, the gbxml created. But when same settings applied using Revit API, create energy model and export to gbxml, there are difference between gbxml created from UI and gbxml created from API.
There are difference properties are missing when gbxml generated from API.
Is there any settings I am missing while generating energy model and exporting  gbxml using the API?
Sharing screenshot of both gbxml for the reference. Could you help me on this, how to solve this issue?
Gbxml generated through Revit UI
Gbxml generated through Revit API
Energy Settings
Replies (0)
