Rotate family instance
devX6MRR
devX6MRR
I'd like to know if there is a way to rotate a just-inserted family instance as shown in the video below.
The video is from AutoCad
MarryTookMyCoffe
are you sure that this is a right kind of forum for this post? It is forum for application programming interface.
do not worry it only gonna take Autodesk 5 years to fix bug
devX6MRR
I'm sure it's the right place Smiley Wink
I'm inserting family with the "PromptForFamilyInstancePlacement" and i'dlike to launch the command to rotate the programmatically.
In the video i attached rotation follows immediately the insertion because the program provide to it.
I hope being more clear now.
IbrahimNaeem
public void RotateColumn(Autodesk.Revit.DB.Document document, Autodesk.Revit.DB.Element element)
    XYZ point1 = new XYZ(10, 20, 0);
    XYZ point2 = new XYZ(10, 20, 30);
    // The axis should be a bound line.
    Line axis = Line.CreateBound(point1, point2);
    ElementTransformUtils.RotateElement(document, element.Id, axis, Math.PI / 3.0);
from the RevitAPI.CHM
Thanks, Ibrahim Naeem
Here Goes:
LocationPoint lp = familiyinstance.Location as LocationPoint;
 XYZ ppt = new XYZ(lp.Point.X, lp.Point.Y, 0);
Line axis = Line.CreateBound(ppt, new XYZ(ppt.X, ppt.Y, ppt.Z + 10));
using (Transaction t = new Transaction(Command.doc, "Rotate"))
t.Start();
 ElementTransformUtils.RotateElement(Command.doc,familiyinstance.Id, axis, (Math.PI / 180) * (angle);
 t.Commit();
Thanks & Regards
Sanjay Pandey
devX6MRR
I'm sorry but i had a problem with another project and I could check solutions only this morning.
The solution best fit my problem is the @Anonymous's one.
I'd like to ask another thing: how can i get the variable angle the i saw in the snippet?
Thank you again
Giorgio
