ROOM_CALCULATION_POINT parameter
I am trying to read out the parameter that gives the room the object is in, the ROOM_CALCULATION_POINT parameter.
I want to apply this on doors and families.
I can read he other parameters of these object, but get stuck by the options SpatialElementCalculationPoint and SpatialElementFromToCalculationPoints.
Can anybody give me some direction how I can do this?
A bit of code would be nice.
I would really appreciate it,
Tiny
Joe.Ye
Hi Tiny,
You can get the family object, and get the family instance. Then get the parameter(ROOM_CALCULATION_POINT).
And change its value.
Here is the code fragment
<code>
//doc is the family document.
Family fam = doc.OwnerFamily;
Parameter param = fam.get_Parameter(BuiltInParameter.ROOM_CALCULATION_POINT);
<code>
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Thank you for your reaction.
If I understand you correctly, this is the code to set the Parameter in the
Family.
When I set the parameter, with what code can I read it out for all the
families and door/windows in the model.
The parameters that I want to read are the Room name and number.
Tiny
Joe.Ye
Hi Tiny,
Not quite sure I got your idea.
Answer your latest question:
Using the following code you can get the parameter of ROOM_CALCULATION_POINT.
<code>
[TransactionAttribute(Autodesk.Revit.Attributes.TransactionMode.Manual)]
public class RevitCommand : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string messages, ElementSet elements)
UIApplication app = commandData.Application;
Document doc = app.ActiveUIDocument.Document;
Selection sel = app.ActiveUIDocument.Selection;
Reference ref1=sel.PickObject(ObjectType.Element, "please pick a window/door");
FamilyInstance inst = doc.GetElement(ref1) as FamilyInstance;
if(inst == null)
messages = "No family instance was picked";
return Result.Failed;
Family family = inst.Symbol.Family;
Parameter param1 = family.get_Parameter(BuiltInParameter.ROOM_CALCULATION_POINT);
if (param1 != null)
//Get the parameter value.
return Result.Succeeded ;
<code>
Which element/object do you want to get the Room name and number? from the window or door? Are you trying to get the room nam name and room number from a given door/window?
Joe Ye
Contractor
Hi Joe,
I going to try to implement this in my code.
With kind regards,
Tiny
Hi!
I´m quite new to coding and Macro Manager in Revit, but is it possible to have a parameter for the doors which would pretty much indicate the following: Room Calculation Point TO = Room name. So if I create a door tag, I could add a label indicating where the door is opening to.
I´m using Revit 2016.
Sten
