Alignment reference plane.
Message 1 of 10
I have an alignment problem. I want to align two reference planes in a family document. But I get this error:
"one of the conditions for the inputs was not satisfied. Consult the documentation for requirements for each argument."
doc : family document with several reference plane.
Extrait du code :
View pViewPlan = findElement(typeof(ViewPlan), "Niveau de réf.", doc) as View;
ReferencePlane refLeftdocFamily = findElement(typeof(ReferencePlane), "Gauche", doc) as ReferencePlane;
ReferencePlane refRightdocFamily= findElement(typeof(ReferencePlane), "Droite", doc) as ReferencePlane;
transaction = new Transaction(doc);
transaction.Start("Alignment");
doc.FamilyCreate.NewAlignment(pViewPlan, refLeftdocFamily.Reference, refRightdocFamily.Reference); "Here this line causes the error described above"
transaction.Commit();
Merci d'avance.
Bonne journée.
Replies (9)
Message 2 of 10
Joe.Ye
Cannot see the cause of this problem with these info.
Are the two reference plane parallel?
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Message 3 of 10
Yes,  I have two reference plane parallel
But I read in the revit api 2013, no alignment of two reference plane
These two references must be one of the following combinations:
  • 2 planar faces
  • 2 lines
  • line and point
  • line and reference plane
  • 2 arcs
  • 2 cylindrical faces
These references must be already geometrically aligned (this function will not force them to become aligned).
Message 4 of 10
Joe.Ye
Hi Bonne journée,
You got. This API doesn't support two reference plane.
You can just move one reference and make it aligning with the other.
Joe Ye
Contractor
Message 5 of 10
Can you explain the methods to do ?
thank you
Message 6 of 10
Joe.Ye
Hi Bonne,
You can use ElementTransformUtils.MoveElement() to move one reference plane.
public static void MoveElement(
Document document,
ElementId elementToMove,
XYZ translation
Joe Ye
Contractor
Message 7 of 10
The problem is that I can not align a reference plane in a nested in another family that has reference plane family.
explanation:
family A
family B
Family B is nested in the family A, these families have reference planes. I want to bring a family plan B on a family plan A. The method can not move market if the plans are on the same document.
Message 8 of 10
Joe.Ye
Sorry, I am not quite clear of the description.
Why you cannot align a reference plan in a nested with another family?
What's the problem in this situation?
Thanks for your more info.
Joe Ye
Contractor
Message 9 of 10
I have 2 families, F01, F02. I load F02 in  F01. And I inserted the point XYZ (0,0,0).
I edited the F02 family located in the F01 family to get his reference plane "Axe Gauche".
I want to align the reference plane "Axe Gauche" (F02) with the plane of reference "Axe Centre" (F01).
Is this possible?
Message 10 of 10
Luis_Salazar
Can you please create an example of a simple alignment? I am struggling with that. The movie to see how create an alignment is not clear.
