Roof edge
Roof edge
even_suzanne
Roof edge
even_suzanne
Hello, I am currently creating a prototype chatbot safe revit that answers simple questions such as how many wall, how many fixtures etc for the uninitiated. The problem is that I can't get the roof edge information, it tells me there is no roof edge whereas I have one in the capture below. Here the capture is in French the selection is marked "bord de toiture" but roof edges in EN
And I also saw that in revit dsk tools roof edges in BuiltInCategories is "OST_Fascia" so I modified my code accordingly, but nothing helped.
Thanks in advance for your help !
public static class RoofEdgeAnalysis
    // Initialisez la catégorie BuiltInCategory pour OST_Fascia.
    public static readonly BuiltInCategory BuiltInCategories_OST_Fascia = BuiltInCategory.OST_Fascia;
    public static string AnalyzeRoofEdges(Document doc)
        List<RoofEdgeInfo> roofEdgeDetails = GetRoofEdgeDetails(doc);
        if (roofEdgeDetails.Count == 0)
            return "Il n'y a aucun bord de toit dans le projet.";
        StringBuilder roofEdgeSummary = new StringBuilder();
        roofEdgeSummary.AppendLine($"Il y a un total de {roofEdgeDetails.Count} bord(s) de toit dans le projet, réparti(s) comme suit :");
        foreach (var roofEdge in roofEdgeDetails)
            roofEdgeSummary.AppendLine($"- {roofEdge.TypeName}, longueur : {roofEdge.Length:F2} m, hauteur : {roofEdge.Height:F2} m");
        return roofEdgeSummary.ToString();
    private static List<RoofEdgeInfo> GetRoofEdgeDetails(Document doc)
        List<RoofEdgeInfo> roofEdgeDetails = new List<RoofEdgeInfo>();
        FilteredElementCollector collector = new FilteredElementCollector(doc)
            .OfCategory(BuiltInCategories_OST_Fascia)
            .OfClass(typeof(FamilyInstance));
        foreach (FamilyInstance element in collector)
            Parameter lengthParam = element.LookupParameter("Longueur");
            Parameter heightParam = element.LookupParameter("Hauteur");
            double length = 0;
            double height = 0;
            if (lengthParam != null && lengthParam.StorageType == StorageType.Double)
                length = lengthParam.AsDouble();
                // Utilisez UnitUtils pour convertir les unités internes de Revit en mètres.
                length = UnitUtils.ConvertFromInternalUnits(length, UnitTypeId.Meters);
            if (heightParam != null && heightParam.StorageType == StorageType.Double)
                height = heightParam.AsDouble();
                height = UnitUtils.ConvertFromInternalUnits(height, UnitTypeId.Meters);
            roofEdgeDetails.Add(new RoofEdgeInfo(element.Name, length, height));
        return roofEdgeDetails;
Moustafa_K
On quick look over your code I see you used Ost_Fascia as family instance, which is not.
You should omit line 30.
if you want to get the instances, you might use it like this:
    .OfCategory(BuiltInCategory.OST_Fascia)
    .WhereElementIsNotElementType();
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
