Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit Visable Bug In Revit Revit 2017 -
1 ANTWORT 1
Nachricht 1 von 2
scgq425
191 Aufrufe, 1 Antwort
this is a discuss about :   place the generation template family and change the family shoule place base the workplane , but when i use code to place this , the revit will just visable one cant-select line in 3d view , but when i change create a new family which use the base-face family template and load this higher then 2019 , the family will visable .
so why this family cant visable , when i use genetation and change the paramater which base face .
use API :
public unsafe Autodesk.Revit.DB.FamilyInstance NewFamilyInstance(
Reference reference,
Autodesk.Revit.DB.XYZ location,
Autodesk.Revit.DB.XYZ referenceDirection,
Autodesk.Revit.DB.FamilySymbol symbol)
the 'AAAA.rfa' is create by model generic model family template
the 'BBBB.rfa' is create by model generic face based family template
the version : Revit 2017 'cant visable the element in 3d view'
Revit 2019 'place by code and visable the element'
LanHui Xu
1 ANTWORT 1
Nachricht 2 von 2
scgq425
als Antwort auf: scgq425
its like some 3d vary error . but i cant analy this error from revit api or code logic .
LanHui Xu
