Ribbon panel button image not displaying
sensiblehira
Message 1 of 12
sensiblehira
Hi I am trying to create my first ribbon button here. Every thing works fine but I cannot get my ribbon image to show as seen in the image
please guide me with what could I be doing wrong.
Replies (11)
Message 2 of 12
corinne.astori
Can you show your code, where you set the image? What image format are you using?
Message 3 of 12
sensiblehira
public Result OnStartup(UIControlledApplication application)
            RibbonPanel panel = RibbonPanel(application);
            string thisAssemblyPath = Assembly.GetExecutingAssembly().Location;
            if(panel.AddItem(new PushButtonData("Room Properties","Room Properties",thisAssemblyPath,"Room_Properties.Command1")) is PushButton button)
                button.ToolTip="Set Unit Targets";
                Uri uri = new Uri(Path.Combine(Path.GetDirectoryName(thisAssemblyPath), "Resources", "SetUnitTargets.ico"));
                BitmapImage bitmap = new BitmapImage(uri);
                button.LargeImage = bitmap;
            return Result.Succeeded;
Message 4 of 12
sensiblehira
I think I cannot get the image files to get copied to AddIn folder
Message 5 of 12
corinne.astori
Try something like this:
myPushButton.LargeImage = GetIcon(myIcon);
Here the method to get the BitmapSource:
private static BitmapSource GetIcon(Icon icon)
{ return Imaging.CreateBitmapSourceFromHIcon(icon.Handle, Int32Rect.Empty, BitmapSizeOptions.FromEmptyOptions()); }
I hope this helps.
KR,
Corinne
Message 6 of 12
corinne.astori
I usually add it to the resources of the project and then refer to it as follow:
myPushButton.LargeImage = GetIcon(MyProject.Properties.Resources.MyIcon);
Message 7 of 12
sensiblehira
I am getting error from the class Icon what reference has to be added for this. I am currently just following the beginner tutorials so I am confused by your answer. Hope you don't mind explaining
Message 8 of 12
corinne.astori
For the Icon class, You need to add a reference to System.Drawing (add using System.Drawing at the top).
Message 9 of 12
sensiblehira
is it from System.Drawing.Icon?
plus I am getting error for the later Image as well
Message 10 of 12
corinne.astori
Yes the Icon class is in System.Drawing.
What error are you getting?
Can you post your current code?
I am sorry if I confused you more than anything else, just trying to help...
Message 11 of 12
sensiblehira
I managed to get the image to show on the panel, thanks for your help. turns out had some issue with the image itself
Message 12 of 12
sensiblehira
