Apps in different versions of Revit
landis.mark
landis.mark
I have developed my app in Revit 20222, using Visual Studio 2022. It installs and works in Revit 2019-2022, but not 2023. I deleted the reverences to RevitAPI and RevitAPIUI.dlls from my solution explorer and added them back from the 2023 folder. That didn't change anything. Is there something I need to do to get it to build and launch 2023 during debugging? and of course install into 2023?
Thanks for any help.
zhuliyi0
which step did you get stuck? Build? Loading into Revit? Any error message? Please provide more specific info.
landis.mark
I found the setting in Visual Studio to get the debug to start Revit 2023. Now my app doesn’t install when starting debug.
I installed App store build of .msi file on a clean machine. The results were the same on Revit versions 2018-2020. The do you want to install warning to install pops up and It installed my Tab and panels. No buttons on the panels. In 2023 it doesn’t install any Tabs or Panels.
zhuliyi0
Did you place your .addin file inside 2023's addin folder? That folder should be:
C:\ProgramData\Autodesk\Revit\Addins\2023
landis.mark
This did solve my problem. I am still trying to work thru the installation from the app store .msi file.
