RevitLinkType & Cloud model
minet.axel
Message 1 of 1
minet.axel
1) How to check if a RevitLinkType comes from the cloud (BIM 360)?
Here is the method I use to determine if the model is from the cloud. Is this valid?
        public static bool IsLinkedModel(RevitLinkType revitLinkType)
            IDictionary<ExternalResourceType, ExternalResourceReference> r = revitLinkType.GetExternalResourceReferences();
            ExternalResourceReference reference = r[ExternalResourceTypes.BuiltInExternalResourceTypes.RevitLink];
            var dictinfo = reference.GetReferenceInformation();
            if (dictinfo.ContainsKey("LinkedModelProjectId") && dictinfo.ContainsKey("LinkedModelModelId"))
                return true;
            return false;
2) Is it necessary to use the Load () function to determine the path of the file ?, Because currently I use this function but sometimes the InSessionPath variable is empty.
    public static string GetPath(RevitLinkType revitLinkType)
            string sessionPath = reference.InSessionPath;
            return sessionPath;
Discussion link: https://thebuildingcoder.typepad.com/blog/2019/06/accessing-bim360-cloud-links-thumbnail-and-dynamo....
 // Obtain all external resource references
  // (saying BIM360 Cloud references and local
  // file references this time)
  ISet<ElementId> xrefs = ExternalResourceUtils
    .GetAllExternalResourceReferences( doc );
  string caption = "BIM360 Links";
  try
    int n = 0;
    var msg = string.Empty;
    foreach( ElementId eid in xrefs )
      var elem = doc.GetElement( eid );
      if( elem == null ) continue;
      // Get RVT document links only this time
      var link = elem as RevitLinkType;
      if( link == null ) continue;
      var map = link.GetExternalResourceReferences();
      var keys = map.Keys;
      foreach( var key in keys )
        var reference = map[key];
        // Contains Forge BIM360 ProjectId
        // (i.e., LinkedModelModelId) and
        // ModelId (i.e., LinkedModelModelId)
        // if it's from BIM360 Docs.
        // They can be used in calls to
        // ModelPathUtils.ConvertCloudGUIDsToCloudPath.
        // Link Name shown on the Manage Links dialog
        var displayName = reference.GetResourceShortDisplayName();
        var path = reference.InSessionPath;
      try
        // Load model temporarily to get the model
        // path of the cloud link
        var result = link.Load();
        // Link ModelPath for Revit internal use
        var mdPath = result.GetModelName();
        link.Unload( null );
        // Convert model path to user visible path,
        // i.e., saved Path shown on the Manage Links
        // dialog
        var path = ModelPathUtils
          .ConvertModelPathToUserVisiblePath( mdPath );
        // Reference Type shown on the Manage Links dialog
        var refType = link.AttachmentType;
        msg += string.Format( "{0} {1}\r\n",
          link.AttachmentType, path );
        ++n;
      catch( Exception ex ) // never catch all exceptions!
        TaskDialog.Show( caption, ex.Message );
    caption = string.Format( "{0} BIM360 Link{1}",
      n, Util.PluralSuffix( n ) );
    TaskDialog.Show( caption, msg );
This returns the path well:
But this one is empty:
Replies (0)
