Document.Create.NewFamilyInstance places element with wrong Z-coordinate
ottosson_mathias
ottosson_mathias
I'm trying to place a new element next to another element.
To do this I have the target element location, which I use to create the new element in the exact same position, as a start... But here is where thing go wrong!
var targetLocation = targetElement.Location as LocationPoint;
var newElement = doc.Create.NewFamilyInstance(targetLocation.Point, familySymbol, targetElement.LevelId, StructuralType.NonStructural);
When I debug and set a break point after the element has been created newElement has position 0, 0, 0! This gets updated after the transaction has been committed, which is fine I guess...
After the commit the element X and Y-coordinates are correct, but not Z which now is a much larger (I've made sure the targetElement.LevelId is correct for the newElement).
Why has the element got correct coordinates in X and Y but not in Z?
Bonus question: Why is the new element position 0, 0, 0 after creation before transaction has been committed?
I'm currently testing my code with Revit 2018.3.3.
Thanks!
David_Robison
What's the elevation of the level you are inserting on?
I did a quick review of my code where I use NewFamilyInstance. I pass the Z-coordinate as 0 and my instance ends up at the elevation of my level. Try setting Z to 0 and see what happens.
ottosson_mathias
No luck... then the Z-elevation is 0 from the current level... as you'd expect!
Maybe it has something to do with units being handled differently for Z-offset? Which feels extremely unintuitive...
ottosson_mathias
Ok, so I think I've figured out the problem...
When I get the point for the target element I get the absolute Z-offset not the floor offset! So I first have to get the parameter value and create a new XYZ like so:
var floorOffset = targetElement.get_Parameter(BuiltInParameter.INSTANCE_FREE_HOST_OFFSET_PARAM).AsDouble()
var offset = new XYZ(targetObjectPoint.X, targetObjectPoint.Y, floorOffset);
A little bit weird that you get the absolute offset value, not the floor offset value, but at the same time it makes sense. Maybe there should be a more intuitive way to get the floor offset.
