Revit will not Install.
I previously had Revit 2018 installed on my computer. I removed it from the C drive to clear up some space. I tried to reinstall it on another drive and I always get an error that it will not install. I have tried Revit 2018, 2020, and 2021. They all error out. I was able to Install 2021 on a slower laptop I have. But still no go with the main computer. I followed the tutorial to super uninstall the program and it still won't download.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage, or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not-for/td-p/5607765
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
