Revit Un-installation Problem
Referring to the above mentioned subject, I'm asking for a solution to un-install Revit Software, I've Windows 7 ,, and every time I try to un-install, a message appears -attached picture - ... What the problem so ?
Thank you in advance for your cooperation
mhillis
By any chance, are you trying to install the latest Revit while uninstalling a previous Revit?  If that's the case, then that would be the cause for your issue.  Other Autodesk installations can kind of conflict with each other when they're running together.
If that isn't the case, then I highly recommend restarting your computer and then immediately trying again once it restarts.  Because, in this case, a set-up process is open somewhere (possibly in the background) and restarting is the quickest way to shut it down.
