Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit.TestRunner - Run UnitTests in Revit
7 REPLIES 7
Message 1 of 8
tobias.floescher
1064 Views, 7 Replies
Hello Developers,
In 2018 I start to program in Revit API environment. It was completely new to me, so I had to get familiar with the API and its peculiarities. I found the blog of @jeremytammik , which helped me a lot.
We insourced an addin, which was developed by an external company. The hole code lives in an assembly which references the Revit API. Then I realized, testing is hard. I refactured the code, that it was as much as possible independent from the Revit API. This Code was testable as I knew it, tests run on Contiguous Integration. But a lot of Code lasts on the Project referenced to Revit API.
I asked google what to do, but apparently there is not THE way how you solve this problem.
There is some stuff around (ex. RevitTestFramework) which seems cool, but I was not happy with it. At least all I found uses NUnit 2.6. But all my Revit independent Code is tested by the NUnit 3.x. The build server doesn’t like the mix.
As result, I started to write my own TestRunner using NUnit 3. It is far away from perfect, nevertheless I would like to share it with the community.
Please have a look at https://github.com/geberit/Revit.TestRunner
Features so far:
* Using NUnit 3
* No reference to Revit.TestRunner needed in test assembly
* Support of NUnit attributes SetUp and TearDown
* Injection of API objects in test method
* Works as an addin with GUI
* Installation script for libraries
* Post build event in VS project to place addin file
Feedback welcome
Tobias - Geberit Verwaltungs AG
7 REPLIES 7
Message 2 of 8
in reply to: tobias.floescher
Hi!
Nice work!
I've experimented with RevitTestFramework back in the days and found it interesting when I tested it. It used revit journals to start revit automatically and run the test but it often crashed for some reason. I would be great to get this to work in a CI-workflow.
Have you investigated the possibility to get this automated with Forge (https://forge.autodesk.com/blog/design-automation-revit-public-beta-here)?
Message 3 of 8
Dear Tobias,
Thank you for your appreciation.
At first glance, this looks utterly beautiful!
I will give it a go asap!
Thank you ever so much for sharing this!
I will very gladly share it on the blog as well, if I may.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 4 of 8
tobias.floescher
Hi Josy
Thanks! No I haven’t investigated with Forge at this time. But I think it could be a very cool solution, especially our build servers are build agents in azure where we don’t have any access to install something (ex. Revit).
tobias
Message 5 of 8
Hi Jeremy
Would be great if you share it on your blog!
I feel honored, thanks a lot.
Cheers tobias
Message 6 of 8
Message 7 of 8
thank you very much, Jeremy.
(also to correct my terrible English ;))
Message 8 of 8
All thanks to you!
You English is perfectly fine, very minor corrections only!
Jeremy Tammik
The Building Coder
Rail Community
