Revit startup error in visual studio 2022
theuil_a
theuil_a
Since the Windows 24H2 update, I can no longer launch Revit automatically from Visual Studio.
I am getting an error message: Unable to start 'C:\Program Files\Autodesk\Revit 2024\Revit.exe'.
Adrian
Revit : 2024.3.1
Visual Studio Professional 2022 : 17.12.3
Windows 11 24H2 : 26100.2605
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @theuil_a ,
Could you confirm if you can manually open Revit and access the documents without any issues?
Is the problem isolated to the API?
Additionally, please review the following link for reference:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Windows-11-support...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Crashes-in-Revit-a...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Crash-or-very-long...
It appears that the issue can also be reproduced manually in the Revit UI.
Could you clarify if the issue is exclusive to the API?
Also, Kindly review the link provided below.
https://stackoverflow.com/questions/78542676/visual-studio-2022-refresh-the-process-list-before-atte...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
