CurrentUIDocument ShowElements() not working in Legend View
Sean_Page
Sean_Page
I am working on a feature that allows the User to select an item from a list and then Open the OwnerView and zoom to the element using ShowElements. I have done this for many things in the past, but there are items this time that are in legends.  When I attempt to use this on a Curve or Textbox placed in a Legend I get a popup: 'No Good view could be found'
Short clip showing it working in a FloorPlan, but not Legend view type.
This is simplified python from Dynamo to show the issue in the video.
#Sean Page, 2024
import clr
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import *
clr.AddReference('System')
from System.Collections.Generic import List
clr.AddReference('RevitNodes')
import Revit
clr.ImportExtensions(Revit.Elements)
clr.AddReference('RevitServices')
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
doc = DocumentManager.Instance.CurrentDBDocument
uiapp=DocumentManager.Instance.CurrentUIApplication
uidoc=DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
element = UnwrapElement(IN[0])
TransactionManager.Instance.EnsureInTransaction(doc)
TransactionManager.Instance.TransactionTaskDone()
OUT = DocumentManager.Instance.CurrentUIDocument.ShowElements(element.Id)
Is there something I am missing here? I also attempted to use ZoomAndCenteRectangle() but it would not Zoom, however it did at least center the item.
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
harilalmnCBXDY
Check out;
  • Created Phase of the elements you are trying to show
  • View's Phase filter
  • View's Phase
  • Element category's visibility in the view (VG/VV)
